Inleiding
Prereq for display assembly.
Onderdelen
Geen onderdelen nodig.
  1. Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board. It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    This was the hardest part of the repair for me. The iSight cable was really lodged in its socket. "Walking" the connector as the guide suggests -- i.e. pushing on each side alternately at a 45 degree angle (with more force than I expected) -- eventually worked.
    Katherine Agnew - Antwoord
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Move the iSight camera cable aside.
    • Move the iSight camera cable aside.
    It is pretty much impossible to do this step before you do the next one as the airport cables are in the way.
    maccentric - Antwoord
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Walter Galan
589.128 Reputatie
1.203 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 57
