Ga door naar hoofdinhoud
Inleiding
Use this guide to replace the trackpad. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
    Toby Thurston - Antwoord
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. The lower case is connected to the upper case at the center, with two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. Remove the plastic cover adhered to the battery contact board.
    • Remove the plastic cover adhered to the battery contact board.
    This plastic cover wasn’t included with the new battery so I placed the original one back in. Was it supposed to go back in? This detail wasn’t clear since the original cover didn’t fit exactly over the newer battery connector. Plus any stickiness of adhesive that may have been there was gone.
    arnolfo santoro - Antwoord
    Hi, any issues with you computer after a year? I didn’t put mine back in either…
    Kevin Burlinson -
  4. Remove the following screws securing the battery connector board to the logic board:
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    Top screw in this image was not a T6. I found that a T5 bit fit this one.
    Alex Grayson - Antwoord
    I can not put back top screw holding the plastic part. Help please
    Tatiana Garcia - Antwoord
  5. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    Is adhered to screw beneath, so lift firmly and slowly.
    Andrew - Antwoord
  6. Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    I lost this screw! How important is it? Will it be okay with just the 3 previously removed screws?
    Gerardo Jimenez - Antwoord
  7. Carefully lift the battery connector board up off the logic board. It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  8. Grasp the Interposer with tweezers. An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    WHy to remove battery contact board? Replace can happen without it also, right.
    Behram Beldagli - Antwoord
    You don’t want to work on a live system as you could damage parts
    Dan -
    How can I remove interposer I m not able to remove it
    Raunak - Antwoord
    you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
    duncan rmi -
    What happens if the Battery Contact Board fails?
    racoon2956 - Antwoord
    Be extra careful when tightening down on the interposer. When I powered on upon completion, the battery was not connected. When I opened it back up, I saw that one of the little metal nubs holding the interposer in place had snapped off (the one on the side, not the corner). I was able to carefully tighten the wide head screw back in, watching the alignment, and the battery was successfully recognized. Hopefully the connection holds up.
    Doug Krieger - Antwoord
    Where can I buy a replacement interposer? I may have lost mine in the process of replacing the battery.
    juan.su - Antwoord
  9. Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board. When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
    I keep my fingernails fairly long, very handy for many computer repair jobs. This gives me 10 spudgers over which I have very fine muscular control. It is far easier to pop some of these tiny delicate MacBook parts loose with my nails.
    Ben Myers - Antwoord
  10. Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector. Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
    This step is NOT really necessary. The trackpad can be removed with this cable still in place.
    Robert - Antwoord
  11. Lift and remove the I/O board data cable from the MacBook Pro.
    • Lift and remove the I/O board data cable from the MacBook Pro.
  12. Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board. Move the SSD cable connector out of the way. Move the SSD cable connector out of the way.
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
    Because it is attached to the battery with a tiny bit of tape near where the spudger is in the picture, this cable should probably be loosened. But it is NOT necessary to remove the speaker entirely.
    Robert - Antwoord
  13. Wedge the pointed end of a spudger beneath the right speaker cable connector. Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
    When reassembling be careful that the right speaker wire is flush against the battery. At first, it was slightly touching the airport/bluetooth board causing wifi and bluetooth to not work after restarting.
    Stu - Antwoord
    NOT truly necessary to remove either speaker.
    Robert - Antwoord
    Looks like the pointy end of the spudger tool is used in the picture. That's what I used.
    bill wiley - Antwoord
  14. Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case: Two black 6.8 mm screws
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • Two black 6.8 mm screws
    • One silver 6.3 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
    There are two 6.8mm screws, both fit to the side of the Macbook.
    Bhoom Suktitipat - Antwoord
    Confirming, 2x T5 6.8mm, one with metal sponge stuff on top. And one T5 6.3mm on the bottom right.
    Joris Sewandono - Antwoord
  15. PC Laptop batterijen
    Een snelle fix voor een grote boost.
    Nu winkelen
    Nu winkelen
  16. Lift and remove the right speaker out of the upper case. If necessary, de-route the right speaker cable from its channel in the upper case.
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
    NOT necessary to remove this speaker.
    Robert - Antwoord
    Yes it is…the speakers cover up the three screws on each side that hold in the battery.
    Redwolf - Antwoord
  17. Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board. Gently bend the headphone jack cable to 90° up from the logic board. Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  18. Wedge the tip of a spudger beneath the left speaker cable connector. Gently pry the left speaker cable connector  up off from its socket on the logic board.
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
  19. Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    The 6.3mm screw appears to be on the lower central part of the Macbook that I'm working on.
    Be very careful on this step. If you aren’t you can snap the plastic on the corners where the screws go in. Remember to go slowly when spinning the screws back in, it doesn’t take gorilla torque to tighten them, just take it easy!
    Stacey Deel - Antwoord
  20. Lift and remove the left speaker out of the upper case. Lift and remove the left speaker out of the upper case.
    • Lift and remove the left speaker out of the upper case.
  21. Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity. While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  22. Remove the SSD assembly from the upper case.
    • Remove the SSD assembly from the upper case.
  23. Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total). Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
  24. The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
    Steps 24-34 are UNNECESSARY for this repair! Removing the adhesive portion of the battery is not required to remove the trackpad. Just lift up the top part of the battery that is screwed in and unplug the trackpad cable.
    bizwfshane - Antwoord
    You can use a heat gun to remove the adhesive. Remember you can always add more heat so don’t over do it. I put my heat gun on high for less than 10 seconds at a time
    BRUCEL86 - Antwoord
    Using a heat gun on a lithium-ion battery is not a good idea. You can get away with it if you are careful, but a solvent is much safer. ;)
    Jeff Suovanen -
  25. Now that your MacBook Pro is fully prepped, it's time to prep yourself. iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  26. Pull off the black rubber stopper from your bottle of adhesive remover. Twist to loosen or remove the bottle cap before you cut the applicator tip. This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  27. Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    Can I do this without adhesive remover and just rip off the cells?
    Benoît Mussche - Antwoord
    If you use a heat gun be sure to point the heat gun away from the motherboard. After heating for 10 seconds or less use the blunt end of the metal pry tool as you don’t want to puncture the battery. You don’t need much force as after you have enough heat you will hear it unsticking when you pry at it lightly with the BLUNT end of the metal pry tool. Repeat this step on the other side. You don’t need to heat the cells near the motherboard as they are secured with small screws
    BRUCEL86 - Antwoord
  28. Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell. Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive. Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
    This is the most difficult step. The tip of my spudger got bended and the aluminum case damaged it.
    Ahmed Almulhim - Antwoord
    I also broke a spudger trying to do this. Eventually I figured out it is easier to go in diagonally from the corner, just to one side of the screw hole, and lever until you hear the adhesive pad tear and give way.
    Matt Sephton - Antwoord
    we use a hair dryer and gently blow hot air in between the battery for a good minute before trying to lift it with a spunger. It worked wonderfully! When lifting, just give it constant force upward and you'll hear the battery slowly breaking away from the macbook, and we don't even see glue residues on our macbook at all. Just be patient. :)
    Allen Lin - Antwoord
    Just a note to say that the above comments were written before the liquid adhesive remover was added to the guide—you should definitely NOT be breaking any spudgers using the current procedure, which requires very little force. I recommend using plastic cards rather than spudgers—it's pretty easy to slide them under each battery cell and separate the adhesive once the solvent has done its work.
    Jeff Suovanen - Antwoord
    This is much easier to do using a plastic card. Just slide the card under the side of the battery and rock it back and forth. The battery will separate pretty quickly with minimal residue.
    lukecparr -
    by a plastic card, do you mean a credit card type thing? thanks in advance.
    Jennifer McPherson - Antwoord
    Exactly—one of these or an old credit card should work fine.
    Jeff Suovanen -
    I second this, I also used an old credit card and it totally worked! I did not use any heat or liquid
    yas.siqueira - Antwoord
  29. Insert the spudger along the left-hand side of the leftmost battery cell. Run the spudger up along the left side of the leftmost battery cell. Slightly pry the leftmost battery cell to release it from the adhesive.
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
  30. Repeat the above steps to separate the adjacent battery cell from its adhesive: Apply a few drops of liquid adhesive remover under the battery cell. Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a few drops of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
    I used a flat metal spudger coated with some acetone to slide under the batteries and loosen the adhesive. My plastic spudger broke early on. Finally, I used a plain old large flat-head screwdriver to pry the battery cells loose.
  31. Insert the flat end of a spudger underneath the larger leftmost battery cell. Carefully wedge the spudger inwards, being careful to not damage the battery cells. Pry the larger leftmost battery cell up off the upper case.
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
  32. Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case. Leave the battery cells resting on top of the upper case as shown in the third picture. Leave the battery cells resting on top of the upper case as shown in the third picture.
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
  33. Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro. Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell. Be careful not to puncture or otherwise damage the battery cells.
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
    Puncturing the battery’s protective covering can lead to release of caustic fumes or fire.
    Chris Leeds - Antwoord
  34. Lift the battery as a whole up out of the upper case, and remove the battery. Before installing a new battery, remove all the old adhesive from the MacBook Pro's case. With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
    During battery replacement take care to position the two left and right battery packs inwards and upwards towards the macbook center such, that there is sufficient space for reinstallation of the two speakers!
    Fred Ziegler - Antwoord
    If you're replacing the top case that includes a new battery, can't you skip removal of the battery?
    jaredcastello - Antwoord
    Yes!! If uppercase Assembly(Includes Trackpad, keyboard, Palmrest & BATTERY) is being replaced, there is no need to remove battery from old uppercase assembly.
    lamajr -
    Wie setze ich die Zyklen wieder auf 0 wenn ich einen neuen Akku verbaut habe?
    Albert Zweistein - Antwoord
    @Albert: you don’t need to reset the cycles as it is done automatically.
    John Wayne - Antwoord
    When you are at this step and before you put the new battery in, take the time to clean your computer really well. You will be surprised how much dust/dirt and even pet hairs have gotten into your computer. After I removed the battery, I use a little more of the acetone to clean the bays up and after it dried, I used a tiny bit of Isopropyl Alcohol to make sure there was a good clean area for the new bonding. Make sure you clean the fans. Don’t use a toothbrush or anything like that. If your have a Lowes or Home Depot, you can buy a shop vac attachment kit for about $20, it’s well worth it. Don’t use that air in a can crap, it will put moisture on circuits. Take your time, it’s not a hard task to do everything, just use a little patience.
    thanks to everyone for the helpful comments along with this really good tick list of things to do. The main thing I have learned is, I don’t have the patience to do this so I am taking my macbook pro (early 2013) 90 odd miles to my nearest Apple store with a Genuis bar. They can sort it for me. They might charge a lot to do it, but at least it will be them risking messing the process up not me! Thanks again.
    Really well done on this. I followed it to a T. Perfect. Thank you for all your work on this.
    Stephen Johnson - Antwoord
    Excellently communicated.
    Andrew Goldberg - Antwoord
    I wouldn’t have thought to drain my old battery! (Which means I cannot begin my ‘new battery install’ until later today.
    Hi all,
    After installing the new batteries, my mac is not powering up… Do i need to charge the battery first and then check again? Have anyone faced similar issue before?
    My 1st battery from ifixit came out to be defective and it caused fire at the centre of the long battery. I have got a replacement for the defective piece which i have installed now. However, now i am worried that connecting to power could lead to any potential fire / harm to my mac???
    Already i have spent lot of time in this and it would be very upsetting if this battery spoils my mac!!!
    Any suggestion people???? thanks in advance!
    BR,
    Vijay
    Vijayaprasath Rajendran - Antwoord
    Hi Vijay!
    Uh-oh, we’re sorry to hear about the battery trouble!
    Our batteries come with a 1-year warranty, so this would definitely be something we can assist with. Please feel welcome to reach out via help.ifixit.com and provide our Support team with your order number so that they can look into these battery troubles with you.
    Thanks!
    Kadan Sharpe -
    My Macbook Pro late 2012 battery is swollen. All 6 cells are. I noticed it when I replaced the cooler paste using your excellent guide.
    This Macbook has become a desktop Mac, I don’t carry it around much anymore. Can I just remove the old battery, dispose of it in appropriate channel and use my Macbook Pro without battery always on power cable? This will also increase ventilation. Or will the Macbook Pro refuse to start up in the absence of the battery? I remember this worked on the white Macbook back in the days.
    Hi All,
    Just replaced battery, and am typing this on the live MacBook. The unit fired up as soon as I plugged in the power adapter. Nice. The battery percentage indicator said the battery had approximately 85% power charge. Is this normal? If not, what steps should I take to ensure that this battery is properly calibrated?
    Cheers,
    James
    James Pineda - Antwoord
  35. Use the flat end of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the flat end of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    It looks like you could skip the entire battery removal procedure if you simply left the trackpad cable in place, disconnected it at the trackpad end, and used the old cable on the new trackpad?
    John M - Antwoord
    You could try it, but there’s very little slack in that cable. I think you’ll have a hard time disconnecting the trackpad without straining or tearing the cable.
    Jeff Suovanen -
  36. Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket. Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
    • Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
  37. Wedge the spudger between the trackpad ribbon cable and the upper case. Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
    • Wedge the spudger between the trackpad ribbon cable and the upper case.
    • Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
  38. Insert the tip of a spudger in between the trackpad ribbon cable and the upper case inside the SSD assembly cavity to remove the last of the adhesive. Insert the tip of a spudger in between the trackpad ribbon cable and the upper case inside the SSD assembly cavity to remove the last of the adhesive.
    • Insert the tip of a spudger in between the trackpad ribbon cable and the upper case inside the SSD assembly cavity to remove the last of the adhesive.
  39. Using the tip of the spudger carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity. Using the tip of the spudger carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity. Using the tip of the spudger carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
    • Using the tip of the spudger carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
  40. Remove the following screws securing the trackpad brackets to the trackpad and upper case:
    • Remove the following screws securing the trackpad brackets to the trackpad and upper case:
    • Four 1.9 mm Phillips #000 screws
    • Four 1.4 mm Phillips #000 screws
  41. Use tweezers to remove the two trackpad mounting brackets from the upper case. Use tweezers to remove the two trackpad mounting brackets from the upper case. Use tweezers to remove the two trackpad mounting brackets from the upper case.
    • Use tweezers to remove the two trackpad mounting brackets from the upper case.
  42. To avoid scratching the display, open the computer about 90º and set it on end. Guide the trackpad ribbon cable through the slot cut in the upper case. This will push the trackpad up out of its recess in the top of the upper case. Guide the trackpad out with your other hand, so it doesn't fall.
    • To avoid scratching the display, open the computer about 90º and set it on end.
    • Guide the trackpad ribbon cable through the slot cut in the upper case. This will push the trackpad up out of its recess in the top of the upper case. Guide the trackpad out with your other hand, so it doesn't fall.
  43. Gently pull the trackpad from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad from the upper case, being careful not to snag the ribbon cable.
    • Gently pull the trackpad from the upper case, being careful not to snag the ribbon cable.
Conclusie
19 andere personen hebben deze handleiding voltooid.
Sam Goldheart
382.117 Reputatie
543 handleidingen geschreven
iFixit Lid van iFixit
Community
101 Leden
9.056 handleidingen geschreven
No need at all to do all of this. Unless your ribbon cable is dead. Otherwise just pull up the SSD and that's it. Took 1mn30 to do..
Philippe - Antwoord
Prerequisites: Only need to remove battery, both speakers partially and the long central battery piece, others aren't in the way.
sinwillett - Antwoord
Did not need to remove upper four 1.9 mm Phillips #000 screws in last step to pop out the trackpad on late 2012 model.
Sunny Wood, Macs 'n More
Sunny - Antwoord
I need help with reassembly! Any tips on how to feed that cable back along the sticky channel? I can't get it to go in there!
Ark - Antwoord
Figured that out- remove the top battery! Sorry - didn't read through all the directions carefully!
Ark - Antwoord
This can be done without removing the battery. The touchpad ribbon cable can be disconnected on the logic board, then snaked (gently!!) back out its channel with the battery in place.
It won't thread back through when replacing the touchpad though - it's not stiff enough. Instead, cut a strip of material from a manila folder and thread that through the channel under the battery. Then use masking tape to attach the touchpad cable to the manila strip and pull the strip out towards the logic board. The touchpad ribbon threads through the channel and the masking tape can be removed once it's in place.
Only the battery connector, SSD cable, and SSD carrier need removed.
R.G. Keen - Antwoord
I agree with the last comment. But I would prefer loosening the center battery and lifting it up to guide the trackpad cable easily. This also makes it easier to reinsert it into the connector during reassembly.
Robert - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 46
Afgelopen 30 Dagen: 244
Altijd: 14,749
