Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the following screws securing the trackpad to the upper case:
Four 1.4 mm Phillips #000 screws
Wedge the spudger between the trackpad ribbon cable and the upper case.
Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
Insert the tip of a spudger in between the trackpad ribbon cable and the upper case.
Carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
Once the trackpad is free of the upper case, guide the trackpad ribbon cable through the slot cut in the upper case.
Remove the trackpad from the upper case.
