Ga door naar hoofdinhoud
MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $16.96
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 3, afbeelding 1 van 3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 3, afbeelding 2 van 3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 3, afbeelding 3 van 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Connector: stap 4, afbeelding 1 van 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 6, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 8, afbeelding 2 van 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Contact Board: stap 9, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Battery Contact Board: stap 9, afbeelding 2 van 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Heat Sink Assembly: stap 10, afbeelding 1 van 1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  11. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 11, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 11, afbeelding 2 van 2
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  12. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, I/O Board Data Cable: stap 12, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, I/O Board Data Cable: stap 12, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  13. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 13, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 13, afbeelding 2 van 2
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  14. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 14, afbeelding 1 van 1
    • Lift and remove the I/O board data cable from the MacBook Pro.
  15. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, iSight Camera Cable: stap 15, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, iSight Camera Cable: stap 15, afbeelding 2 van 2
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  16. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 16, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 16, afbeelding 2 van 2
    • Move the iSight camera cable aside.
  17. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: stap 17, afbeelding 1 van 3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: stap 17, afbeelding 2 van 3 MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement, Right Fan: stap 17, afbeelding 3 van 3
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the right fan ribbon cable straight out of its socket on the logic board.
  18. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 18, afbeelding 1 van 1
    • Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
  19. MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement: stap 19, afbeelding 1 van 1
    • Lift and remove the right fan out of the upper case.
Conclusie
7 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
During reassembly, installing the shouldered screw in step 5 caused a shock and fried my computer.
Ian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 73
Altijd: 5,638
