Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use the tip of a spudger to push the edges of the I/O board connector straight out of its socket on the logic board.
Wedge the flat end of a spudger underneath the keyboard backlight connector and the logic board.
Gently twist the flat end of a spudger upwards to pry the keyboard backlight connector up off its socket on the logic board.
Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Pry the headphone jack cable connector up off its socket on the logic board.
Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the microphone ribbon cable out of its socket.
Use the flat edge of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Grasp the plastic pull tab and pull the keyboard ribbon cable out of its socket.
Repeat the previous procedure to disconnect the Trackpad ribbon cable from its socket on the logic board.
Wedge the flat end of a spudger beneath the right speaker cable connector.
Gently pry the right speaker cable connector up off from its socket on the logic board.
Use the flat end of a spudger to pry the SSD cable connector up off its socket on the logic board.
Wedge the tip of a spudger beneath the left speaker cable connector.
Gently pry the left speaker cable connector up off from its socket on the logic board.
Remove the nine 3.3 mm T5 Torx screws securing the logic board and MagSafe DC-in board to the upper case.
Carefully grasp the corner of the logic board (opposite of the I/O ports) and lift the logic board out of the upper case.
