Ga door naar hoofdinhoud
MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement
Wat je nodig hebt
  1. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 3, afbeelding 1 van 3 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 3, afbeelding 2 van 3 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 3, afbeelding 3 van 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Battery Connector: stap 4, afbeelding 1 van 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 6, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 7, afbeelding 1 van 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 8, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 8, afbeelding 2 van 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Battery Contact Board: stap 9, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Battery Contact Board: stap 9, afbeelding 2 van 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Heat Sink Assembly: stap 10, afbeelding 1 van 1
    • Remove the following screws securing the heat sink to the logic board assembly:
    • One 2.4 mm Phillips #00 screw
    • One 3.4 mm T5 Torx screw
    • Four 2.7 mm T5 Torx screws
  11. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 11, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 11, afbeelding 2 van 2
    • Lift and remove the heat sink up off the logic board assembly.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  12. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Left Fan: stap 12, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement, Left Fan: stap 12, afbeelding 2 van 2
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  13. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 13, afbeelding 1 van 1
    • Remove the three 3.1 mm T5 Torx screws securing the left fan to the logic board assembly.
  14. MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 14, afbeelding 1 van 2 MacBook Pro 13" Retina Display Late 2012 Left Fan Replacement: stap 14, afbeelding 2 van 2
    • Lift and remove the left fan out of the upper case.
    • Make sure to pull the left fan straight away to simultaneously pull the left fan ribbon cable out of its socket on the logic board.
Conclusie
7 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 6,922
