Inleiding
Vooraf vereiste handleiding.
Wat je nodig hebt
Verwijder de plastic bescherming die aan het contactbord van de batterij is bevestigd.
Gebruik een pincet om de kleine plastic bescherming bij de rechter onderhoek van het connectorbord van de batterij te verwijderen.
when doing this with metal tweezers as instructed in the video, it was difficult to get off and apparently while i was trying to do it, the tweezers went too far under and i believe made contact with the screw underneath? there was a zzz noise, an orange flicker and a little stream of smoke that came out. i freaked out and put everything back together to see if the laptop even still worked, it turned on and everything but died right away (i drained it before doing the repair anyway, so i was surprised it turned on at all).
i finished the battery repair and did several other things while in there. i have charged it all the way as recommended and will use it later on to see how everything is, im hoping that it’s a okay, but could someone explain to me what happened and the possible consequences?
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
Met dank aan deze vertalers:
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
The replacement cover doesn't seem to have the formed pads attached. I re-installed the original.
Adrien - Antwoord
