Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Verwijder de volgende tien schroeven die de onderste behuizing aan de bovenste behuizing bevestigen:
Twee 2.3 mm lange P5 Pentalobe schroeven
Acht 3.0 mm lange P5 Pentalobe schroeven
Pak de zwarte, plastic lip met je pincet vast en open het contact waar de schermaansluiting op is aangesloten. Trek de kabel van de schermaansluiting vervolgens uit het contact op het moederbord.
Trek de aansluiting in de richting van de kabel en parallel aan het moederbord weg. Trek de kabel niet omhoog.
42 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Since a few days the area around the MagSafe-DC is getting quite hot, regardless of wether the Mac is running or idle. Does this have anything to do with the MagSafe-DC? Any recommendations?
Hi Folks,
Just went through these very clear steps on replacing the DC-in board after the pins on my old one were burned.
First off, success…ish with the replacement and the mac is back to charging again in high spirits. However, I am now notified of a “service battery" beneath the charge drop down menu. In checking the system information, the battery is at a cycle count of 824.
I am not quite sure what to do at this point and appreciate any tips.
Best,
random guy on the internet
Replace the battery.
Hi there !
My mac won't charge the freshly replaced new battery... event tho it's running fine and recognized by the system...
I've been Changing the battery / Reseting SMC & NVRAM / Clean install on Monterey...
It still tells me :
Power source : power adapter
Battery is not charging
Do you think replacing the DC-in board would help ?
Thanks for your advices !
