Ga door naar hoofdinhoud
Inleiding
Wi-Fi on the fritz? Just can't get onto that free coffee shop internet no matter how hard you try? You might need to replace your AirPort Board. Follow this guide to learn how.
    • Two 2.3 mm Pentalobe screws
    • Eight 3.0 mm Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Antwoord
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
    Alex Birkett - Antwoord
    Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
    addvariety -
    the macbook in the picture is 2012. does it has the same structure as 2013?
    Edison - Antwoord
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Antwoord
    is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
    monsieurescargot - Antwoord
    Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
    Antoine Thornton - Antwoord
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Antwoord
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Antwoord
    This is what I found on my MBP mid-2014 13” Retina. All 10 used the same screwdriver. I didn’t see the blue “loctite” but I also got my computer refurbished.
    Evan Shulman -
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
    Just finished replacing my battery (MacBook Pro 13” early 2015), glad I did, the old ones were noticeably swollen. I was surprised to find the battery at 57% upon completion and charging the new battery. No problems with replacement however, kit arrived without the Pentalobe driver. I got a nice complete kit from Amazon for 20 euro in 2 days. iFixit offered a coupon on any future purchase but right now, I have no plans on needing anything. Nice gesture but would have preferred the driver in the kit in the first place.
    Suggest having a small can of compressed air on hand to clean out the interior, after 4 years, mine was quite dirty. Ear buds and alcohol were the best I could do. And a magnetized driver is mandatory I think.
    D M - Antwoord
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Antwoord
    Agreed. A decent amount of force is required here.
    Evan Shulman - Antwoord
  2. The lower case is connected to the upper case with two plastic clips near its center. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    There are two screws that are shorter-they go to the back near the vent.
    wrbandllm - Antwoord
    This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
    addvariety - Antwoord
    What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
    Tommy Huang - Antwoord
    When I got the back off, I found this piece loose, any idea what it is? about 9mm long frosted plastic
    https://imgur.com/a/tYaxGdG
    Fred Anderson - Antwoord
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Antwoord
    I took my pointer and thumb (which are luckily long enough) to feel where the studs are on the back panel, and then as I put the back panel back on, I pushed in the spot I had marked with my fingers to ensure I was applying pressure only on this part.
  3. If necessary, remove the plastic cover adhered to the battery contact board.
    • If necessary, remove the plastic cover adhered to the battery contact board.
    Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
    jodieabc - Antwoord
    There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
    Jaime Leonard - Antwoord
    I replaced both my L and R speakers on my MBP mid-2014 13” withOUT doing this step.
  4. Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board. Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Antwoord
    I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
    salvatorebarbera -
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    Hi,have you find the solution for your battery? I also have same problem, run with plugs but it battery not supporting… as soon the plug of it goes off
    Jewel Rahman -
    Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
    Steve - Antwoord
    Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
    Vadim Gribanov -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Antwoord
    Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
    Caleb Steinborn -
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
    Parth Gudhka - Antwoord
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Antwoord
  5. Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Antwoord
    Not sure I understand: did leaving the battery plugged in permanently broke the I/O board (or anything else)?
    Adrien Izzet -
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Antwoord
    That’s a great idea!
    David Lilliebridge - Antwoord
    I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
    dbrick - Antwoord
  6. Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the center socket.
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  7. Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  8. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board. Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
426.005 Reputatie
411 handleidingen geschreven
iFixit Lid van iFixit
Community
104 Leden
9.255 handleidingen geschreven
Is this responsible for wifi? I re-did my screen and fixed it from blackening, but the wifi icon says "Wi-Fi: No hardware installed". Is this part responsible? If I replace it will I get wifi back?
Howard Lin - Antwoord
I changed the card and the wifi keep disabling itself after few minutes of use. Only reboot reactivate it.. Someone have an idea ?
Phil - Antwoord
Hey! have you found a solution? I have been having the same problem!
juiquebec -
I am having the same exact problem as described by Phil - 04/25/2017
I replaced the card but the wifi and bluetooth keeps disabling itself after few minutes of use , only reboot reactivate it.
I am thinking of changing the antenna ? any ideas? suggestion ?
your help will be very much appreciated .
Lio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 21
Afgelopen 7 Dagen: 159
Afgelopen 30 Dagen: 581
Altijd: 20,040
