Gereedschap
Onderdelen
The screen assembly I am using in this tutorial arrived encased in foam, bubble wrap and styrophome. Quite a pleasure to unpack.
Start with removing the 4 corner screws and the two center screws from around the bottom panel. **NOTE the screws next to the hinge are a different length (longer) than the two at the other two corners, and the two center screws are the shortest. so keep that in mind when putting your MacBook back together.
Now comes the hinge screws. Actually, for the next few steps it probably does not matter what order you remove the screws. But I did the hinges next. These require a T8 diver.
I forgot to get a picture of the hinge caps that will need to be removed first. These required a P3 driver, and the screws are very tiny. Once these screws were removed you can pry off the hinge caps and access the hinges.
17 andere personen hebben deze handleiding voltooid.
4 Opmerkingen
When removing the bottom cover, remember to disconnect the front clips, then slide the whole cover forward to disconnect the rear! Pulling straight upward to disconnect the rear clips may result in your cover bending, or breaking.
