Ga door naar hoofdinhoud
MacBook Pro 13“一体式2009硬盘更换
Wat je nodig hebt
  1. MacBook Pro 13“一体式2009硬盘更换, 后壳: stap 1, afbeelding 1 van 1
    • 移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
    • 7个3 mm Phillips螺丝
    • 3个13.5 mm Phillips 螺丝
  2. MacBook Pro 13“一体式2009硬盘更换: stap 2, afbeelding 1 van 1
    • 轻轻提起后壳然后推向电脑的后方来松开卡舌。
  3. MacBook Pro 13“一体式2009硬盘更换, 电池: stap 3, afbeelding 1 van 1
    • 为了预防意外发生,我们建议您从逻辑板上断开电池连接器,以避免任何放电。
    • 使用一个平端撬棒将电池连接器分离逻辑板插座。
  4. MacBook Pro 13“一体式2009硬盘更换, 硬盘: stap 4, afbeelding 1 van 1
    • 拆下将硬盘固定到支架上盖上的两个十字螺丝。
    • 这些螺丝固定在硬盘支架上。
  5. MacBook Pro 13“一体式2009硬盘更换: stap 5, afbeelding 1 van 1
    • 将固定支架从上盖上提起。
  6. MacBook Pro 13“一体式2009硬盘更换: stap 6, afbeelding 1 van 1
    • 通过其拉片提起硬盘,并将其从外壳中拉出,将电线连接到电脑上。
  7. MacBook Pro 13“一体式2009硬盘更换: stap 7, afbeelding 1 van 1
    • 将硬盘的电线从硬盘上拔下即可。
  8. MacBook Pro 13“一体式2009硬盘更换, 硬盘: stap 8, afbeelding 1 van 2 MacBook Pro 13“一体式2009硬盘更换, 硬盘: stap 8, afbeelding 2 van 2
    • 从硬盘的每一侧(总共四个螺丝)拆下两个T6梅花螺丝。
    • 如果您正在更换硬盘,则需要将这些螺丝装到新的硬盘上。
    • 如果您正在安装新的硬盘,我们有一个OS X安装指南,让您开始运行。
Conclusie
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
568 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en zh
100%
笑得像个300斤的孩子 helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
16 opmerkingen
I'd suggest using the free software "Super Duper" to clone the hard drive. It worked wonders for me and after the 2 hour clone, I was up and running in 5 minutes!
cmoore22739 - Antwoord
I wholeheartedly agree. Super Duper! made the task effortless.
danzeitlin -
The T6 torx screws on the side of the existing Hitachi drive fit my Crucial M500 240GB replacement perfectly. Be aware that they were originally installed into the HDD with blue Loctite, so it takes a bit of effort to break them loose.
Thanks ifixit for excellent guidance!
danzeitlin - Antwoord
What do you do when your laptop doesn't read your new hard drive?
amberscheme - Antwoord
If your hard drive dosent connect. you might need to change your hard drive connect cable . The second option is that you need a strip to replace your hard drive with DVD rom.
Asim Rafaq -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 71
Afgelopen 30 dagen: 322
Altijd: 624,225
