Inleiding
Corrosion? Bent pins? Whatever the problem, use this guide to replace your MacBook battery's connection to the logic board.
Gereedschap
Onderdelen
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
23 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
My rev 1,1 white Macbook was missing the spacer.
So was mine. Also make note for comparison, the Apple Service Source manual states that the I/O Panel needs to be removed prior to removing the connector - happily, according to iRobot, you don’t have to.
