Ga door naar hoofdinhoud
MacBook Core 2 Duo Upper Case Clips Replacement
Wat je nodig hebt
  1. MacBook Core 2 Duo Upper Case Clips Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Upper Case Clips Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Upper Case Clips Replacement, Memory Cover: stap 3, afbeelding 1 van 1
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. MacBook Core 2 Duo Upper Case Clips Replacement: stap 4, afbeelding 1 van 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
  5. MacBook Core 2 Duo Upper Case Clips Replacement, Upper Case: stap 5, afbeelding 1 van 1
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle of the lower case.
  6. MacBook Core 2 Duo Upper Case Clips Replacement: stap 6, afbeelding 1 van 1
    • Take extra caution with these screws as they can strip easily!
    • You could use a flexible extension to minimize stripping.
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  7. MacBook Core 2 Duo Upper Case Clips Replacement: stap 7, afbeelding 1 van 1
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
  8. MacBook Core 2 Duo Upper Case Clips Replacement: stap 8, afbeelding 1 van 1
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
  9. MacBook Core 2 Duo Upper Case Clips Replacement: stap 9, afbeelding 1 van 1
    • Remove the following 4 screws from the back of the computer:
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
  10. MacBook Core 2 Duo Upper Case Clips Replacement: stap 10, afbeelding 1 van 1
    • Remove the two Phillips screws from the optical drive (right) side of the computer:
    • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the ports (left) side of the computer.
  11. MacBook Core 2 Duo Upper Case Clips Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
    • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
    • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
    • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
  12. MacBook Core 2 Duo Upper Case Clips Replacement: stap 12, afbeelding 1 van 3 MacBook Core 2 Duo Upper Case Clips Replacement: stap 12, afbeelding 2 van 3 MacBook Core 2 Duo Upper Case Clips Replacement: stap 12, afbeelding 3 van 3
    • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
    • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
  13. MacBook Core 2 Duo Upper Case Clips Replacement, Upper Case Clips: stap 13, afbeelding 1 van 3 MacBook Core 2 Duo Upper Case Clips Replacement, Upper Case Clips: stap 13, afbeelding 2 van 3 MacBook Core 2 Duo Upper Case Clips Replacement, Upper Case Clips: stap 13, afbeelding 3 van 3
    • The clips are captive to the lower case on Santa Rosa MacBooks and later and are thus not replaceable on these models.
    • The four plastic upper case clips are installed in the aluminum framework above the optical drive opening.
    • To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
Conclusie
10 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Thanks for the help, I was able to complete the task. It's just that I had a glitch hiccup on the fifth step, but it all worked out in the end. io games
Thank you one more.
Tom Cruise - Antwoord
Thank you for your guide, I followed it and it worked. helix jump
cie kalyl - Antwoord
Thank you weaver game for giving this world a new color. It also helps me a lot to teach me how to love life, love people and appreciate everything around.
russia russia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 9,035
