Inleiding
The RAM cover keeps the RAM detachment lever from interfering with the battery and plays a role in protecting the HDD.
Wat je nodig hebt
Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
To reassemble your device, follow these steps in reverse order.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
