Ga door naar hoofdinhoud
Inleiding
This keeps the RAM levers out of the way of the battery and secures the hard drive.
  1. MacBook Core 2 Duo Memory Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Memory Cover Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Memory Cover Replacement, Memory Cover: stap 3, afbeelding 1 van 1
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
  4. MacBook Core 2 Duo Memory Cover Replacement: stap 4, afbeelding 1 van 1
    • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
Conclusie
54 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
646 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 33,869
