Ga door naar hoofdinhoud
MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement
Wat je nodig hebt
  1. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the screws securing the lower case: stap 1, afbeelding 1 van 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the lower case: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Disconnect the battery: stap 3, afbeelding 1 van 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 4, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the right speaker adhesive: stap 5, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the right speaker adhesive: stap 5, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the right speaker adhesive: stap 5, afbeelding 3 van 3
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • If the adhesive strip breaks, leave it in and proceed to the next step.
  6. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 6, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 6, afbeelding 2 van 2
    • Slide the tip of a spudger underneath the right speaker cable and pry straight up to disconnect the speaker.
  7. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 7, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 7, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 7, afbeelding 3 van 3
    • Use tweezers to lift the adhesive pull tab at the top of the right speaker enough that you can grab it with your fingers.
    • If the adhesive strip breaks, or if the first adhesive strip broke, use a heated iOpener or heat gun to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the right speaker: stap 8, afbeelding 1 van 1
    • Lift the right speaker straight up from the bottom and remove it.
  9. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the left speaker adhesive: stap 9, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the left speaker adhesive: stap 9, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the left speaker adhesive: stap 9, afbeelding 3 van 3
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the left speaker, enough so you can grab it with your fingers.
  10. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 10, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 10, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 10, afbeelding 3 van 3
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  11. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 11, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 11, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 11, afbeelding 3 van 3
    • Use tweezers to lift the adhesive pull tab at the top of the left speaker enough that you can grab it with your fingers.
  12. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the left speaker: stap 12, afbeelding 1 van 1
    • Lift the left speaker straight up from the bottom and remove it.
  13. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Disconnect the logic board: stap 13, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Disconnect the logic board: stap 13, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  14. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 14, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 14, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  15. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 15, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 15, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 15, afbeelding 3 van 3
    • If the left speaker is already disconnected, skip this step.
  16. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 16, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 16, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  17. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 17, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 17, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  18. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 18, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 18, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 18, afbeelding 3 van 3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  19. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 19, afbeelding 1 van 1
    • Peel back the black tape covering the fan cable connector.
  20. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 20, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 20, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 20, afbeelding 3 van 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  21. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 21, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 21, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  22. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 22, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 22, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 22, afbeelding 3 van 3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  23. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 23, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 23, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  24. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 24, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 24, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up the display cable connector.
  25. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Unscrew the logic board: stap 25, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the following screws:
    • One 5.5 mm screw
    • Three 2.6 mm screws
    • Two 1.9 mm screws
  26. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the logic board: stap 26, afbeelding 1 van 1
    • Remove the logic board.
  27. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Unscrew the battery: stap 27, afbeelding 1 van 1
    • Use a T3 Torx driver to remove four 2.5 mm screws securing the battery.
  28. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the battery adhesive: stap 28, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the battery adhesive: stap 28, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the battery adhesive: stap 28, afbeelding 3 van 3
    • Use a pair of tweezers to lift up the black adhesive pull tab on the side of the battery, enough so you can grab it with your fingers.
    • Grab the adhesive strip pull tab and slowly and carefully pull the adhesive strip out from under the battery.
  29. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 29, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 29, afbeelding 2 van 2
    • Repeat the previous step to remove the next two adhesive strips on the same side of the battery.
    • If any adhesive strips break, leave them in and proceed to the next step.
  30. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 30, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 30, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 30, afbeelding 3 van 3
    • Repeat the previous two steps to remove the three adhesive strips on the other side of the battery.
    • If any of the adhesive strips broke, you can use high-concentration (>90%) isopropyl alcohol to help remove them:
    • Carefully drip isopropyl alcohol along either edge of the battery, in the recessed part of the upper case, where the adhesive pull tabs were.
    • Applying too much alcohol or applying it outside of the wells in the case where the adhesive sits risks damaging other components.
    • Let the alcohol soak into the adhesive for a minute or two.
    • Use opening picks to gently pry the battery away from the upper case.
  31. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the battery: stap 31, afbeelding 1 van 1
    • Remove the battery.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  32. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the microphone assembly: stap 32, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement, Remove the microphone assembly: stap 32, afbeelding 2 van 2
    • Slide an opening pick under the microphone farthest away from the edge of the case to slice through the adhesive securing it to the upper case.
    • The microphone assembly is still connected to the case. Do not try to remove the microphone assembly or lift the cable.
    • If the adhesive is stubborn, do not force the pick. Heat the microphone assembly using an iOpener or a hair dryer to soften the adhesive.
  33. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 33, afbeelding 1 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 33, afbeelding 2 van 3 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 33, afbeelding 3 van 3
    • Use the point of a spudger to lift the small locking flap on the microphone's ZIF connector.
    • Slide the microphone cable straight out of the ZIF connector.
  34. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 34, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 34, afbeelding 2 van 2
    • Slide an opening pick under the rest of the microphone assembly cable to separate it from the adhesive securing it to the upper case.
  35. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 35, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 35, afbeelding 2 van 2
    • Use the point of a spudger to carefully pry one of the microphones out of its recess in the upper case.
    • If the adhesive is stubborn, it may be necessary to apply heat to the microphone or the case.
  36. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 36, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 36, afbeelding 2 van 2
    • Use the point of a spudger to carefully pry the other microphone out of its recess in the upper case.
  37. MacBook Air 13" Retina Display 2019 Microphone Assembly Replacement: stap 37, afbeelding 1 van 1
    • Remove the microphone assembly.
Conclusie
Adam O'Camb
196.194 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 1,140
