Ga door naar hoofdinhoud
MacBook Air 13" Retina Display 2019 Audio Board Replacement
Wat je nodig hebt
  1. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Remove the screws securing the lower case: stap 1, afbeelding 1 van 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Remove the lower case: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Disconnect the battery: stap 3, afbeelding 1 van 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 4, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Disconnect the right speaker: stap 5, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Audio Board Replacement, Disconnect the right speaker: stap 5, afbeelding 2 van 2
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
  6. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Disconnect the audio board: stap 6, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Audio Board Replacement, Disconnect the audio board: stap 6, afbeelding 2 van 2
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
  7. MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 7, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
  8. MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 8, afbeelding 1 van 2 MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 8, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
  9. MacBook Air 13" Retina Display 2019 Audio Board Replacement, Remove the audio board: stap 9, afbeelding 1 van 1
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
  10. MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 10, afbeelding 1 van 1
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
  11. MacBook Air 13" Retina Display 2019 Audio Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the audio board.
Conclusie
Adam O'Camb
196.116 Reputatie
416 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 64
Altijd: 3,097
