Inleiding
Prereq for upper case (logic board is removed)
Wat je nodig hebt
Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
Bijna klaar!
Conclusie
I did not remove the display assembly at all. I replaced both the trackpad and keyboard without removing the display assembly.
airshack - Antwoord
If you purchase the upper case with the keyboard as one unit you then have to remove the display assembly as the keyboard is part of the upper case
jheller105 - Antwoord
