Ga door naar hoofdinhoud
Inleiding
No sound from the right side of your MacBook Air? Use this guide to replace the right speaker.
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Mid 2012 Right Speaker Replacement, Battery: stap 3, afbeelding 1 van 2 MacBook Air 13" Mid 2012 Right Speaker Replacement, Battery: stap 3, afbeelding 2 van 2
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  3. MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  4. MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 5, afbeelding 1 van 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  5. MacBook Air 13" Mid 2012 Right Speaker Replacement, Right Speaker: stap 6, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the right speaker connector up and out of its socket on the logic board.
    • Pry up from beneath the wires.
  6. MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 7, afbeelding 1 van 3 MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 7, afbeelding 2 van 3 MacBook Air 13" Mid 2012 Right Speaker Replacement: stap 7, afbeelding 3 van 3
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Remove the right speaker from the upper case.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
487.801 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
145 Leden
15.529 handleidingen geschreven
2 Opmerkingen
When you unhook the connector to the speaker, do not put the spudger too far under and snap off the holder from the logic board like I did.
I am guessing, put I assume you just get the edge right next to the wires.
This should be explained better.
Thanks anyway.
Jeff Beckett - Antwoord
Hello, thank you for sharing this guide! I have managed to replace the left speaker of my MacBook but it seems that the left speaker sounds different than the right speaker. Is that expected or is my second-hand speaker broken?
The left speaker seems to be more bass-heavy and muffled.
Rafał Karoń - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 6,069
