Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Gebruik een P5 Pentalobe-schroevendraaier(bitje) om de tien schroeven die de onderste behuizing bevestigen te verwijderen. Deze hebben de volgende lengtes:
Twee 9 mm lange schroeven
Acht 2.6 mm lange schroeven
Deze stap is niet vertaald. Help het te vertalen
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Slightly lift up the end of the SSD and pull it straight out of its socket on the logic board.
86 andere personen hebben deze handleiding voltooid.
8 opmerkingen
If I replace the SSD with another one purchased from iFixit, will it appear as an external or internal drive?
At my job, it's standard to encrypt drives. I purchased an SSD from another vendor and because it showed as external, couldn't be encrypted. I just want to avoid this problem before purchasing one from here.
Muito bom o roteiro, deu certinho.
This should really be rated as easy. Took less than 5 minutes thanks to this excellent guide.
Absolutely spot on. Thanks Andrew! The only potential pitfall in this job is getting the right replacement SSD (or, if you're extracting the SSD to use elsewhere, getting the right caddy.)
anybody knows if exist any hdd to replace the ssd?
I have a mb air 13 mid 2011 in my hands and it has behaviour a mac(/pc) with a hdd damaged? same noise, same latencies, same way to damage files…
and over the top “informations about this mac” says it is a macbook pro 13
never seen in my life…
