Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Internal Prerequisite.
Wat je nodig hebt
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Be sure you are prying up on the hinged retaining flap, not the socket itself.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Excellent guide, thank you very much.
Logic board removed from my daughter’s Air, cooked for 8m at 200C, cooled, reinstalled, and now works again.
I was able to remove and replace the 5th heatsink retaining screw without moving the antenna retainer.
Cheers, Aidan
