Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a noisy MacBook Air 13" Early 2015 fan, or simply remove it for cleaning.
Wat je nodig hebt
Video overzicht
Gereedschap gebruikt in deze stap:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
39 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Hello! I just broke the flap/hinge on the ZIF socket connecting the fan ribbon. What do I do now? Is a replacement ZIF socket available?
The zif connector just detached from the board when attempting to open the hinge with spudger. I’ve tried to solder the zif connector back to the board but the connector is so small that I haven’t been successful.
I cannot order this item in the German store, I get directed to the US store, why?
