Inleiding
Use this guide to replace the trackpad.
Wat je nodig hebt
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
32 andere personen hebben deze handleiding voltooid.
10 opmerkingen
there are times when my trackpad wont click. Is there a reason why?
This often happens due to a swollen battery. It bumps up against the bottom of the trackpad, preventing it from clicking down. It tends to get worse over time. If removing the battery allows your trackpad to click normally, or if the battery is visibly swollen, replace your battery right away.
When I reinstall my trackpad, there is too much "play" or too much room for clicking. It seems like the set screw is screwed in farther than it was originally, and it still doesn't seem to be enough. Also, the mouse isn't working; it won't move, and the click doesn't cause any action. What did I do wrong?
Thank you !
I fixed my trackpad!
