Inleiding
Use this guide to replace the fan.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
27 andere personen hebben deze handleiding voltooid.
3 opmerkingen
I think you’re using a different model of a macbook air because the 2014 model has a different battery connector that you shouldn’t lift up bcs you can broke it
