Ga door naar hoofdinhoud
MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement
Wat je nodig hebt
  1. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Koop
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, Battery Connector: stap 3, afbeelding 2 van 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: stap 4, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: stap 4, afbeelding 2 van 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 6, afbeelding 1 van 2 MacBook Air 13" Early 2014 AirPort/Bluetooth Card Replacement: stap 6, afbeelding 2 van 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
Conclusie
27 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
427.925 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.757 handleidingen geschreven
4 opmerkingen
Very helpful! Tweezers were helpful to connect the reconnect the antenna connectors
James Walsh - Antwoord
Will a 2012 MBA wifi antenna work with a 2014 wifi card?
Archie - Antwoord
I'm getting a "Wifi: No hardware installed" with an X over the wifi icon in the Menu.
Even after I swapped the original Airport card with a second one. Neither one works. The original worked up until a short time ago. I hadn't used the Air for a few months, but when I started it up the Airport wasn't recognized.
Also, should mention that Bluetooth works fine.
Could it be the Airport cables?
Specs: 13" Air (2014) running Mojave 10.14.1
Simple Simon - Antwoord
I use a Netgear router with a Macbook Air 13, and the internet is very slow with it, and the connection is always disconnected and back on.
Bassem Abaza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 59
Altijd: 19,281
