Inleiding
Use this guide to replace the lower case on your 2018 MacBook Air, or to remove it for further repair.
Gereedschap
Onderdelen
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Één andere persoon heeft deze handleiding voltooid.
