Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
While holding the lock away from the socket, gently pull the display data cable out of its socket.
Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
De-route the cable from its notch in the logic board.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
Pull the keyboard backlight ribbon cable out of its socket.
Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
In some models these are 3.1 mm T5 Torx screws.
Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
Één andere persoon heeft deze handleiding voltooid.
