Inleiding
Use this guide to replace a worn-out battery.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
301 andere personen hebben deze handleiding voltooid.
58 opmerkingen
Arrived with 52% charge, capacity 4593 mAh of 4680 mAh. 98% health, manufacture date of the iFixit replacement battery is Feb 4 2012 (2.9 years), with 0 charge cycles. My order arrived extremely fast, and replacing the battery itself was easier than expected. Overall speed of my MBA seems to have improved somewhat as well. Despite my MBA mid-11 being almost 3.5 years old, the internals, fan included, were all fairly free from dust. So far, so good.
I removed a battery pack from a mid-2011 MBA. Two of the lithium polymer cells had expanded so much that the upper case was bulging out about 0.5cm. The bulge un-bulged itself as soon as I loosened the screws on the lower case. There doesn't seem to be any significant damage to the hardware. Pretty wild. Also, despite this repair being listed as "Difficulty: Moderate", it's about the easiest thing you can do that involves opening the bottom cover.
THIS IS FANTASTIC!! I ordered it on a Thursday & received it on a Saturday! Came very protected in the box. It took me only 40 min to replace the battery & these instructions were excellent to follow! I highly recommend!
I would like to agree: the difficulty is even less than easy
