Inleiding
Restore sound to your mini by replacing the speaker.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
We will first remove the AirPort antenna, located in the lower left corner of this picture.
Remove the two Phillips screws connecting the underside of the hard drive to the internal frame.
Disconnect the speaker cable connector from the interconnect board by lifting its connector up off the socket on the board.
3 andere personen hebben deze handleiding voltooid.
