Inleiding
Replace your IR board to regain control of your mini via an Apple remote.
Onderdelen
Geen onderdelen nodig.
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Remove the Bluetooth antenna from the internal frame by pushing up on both sides of the board as close to the center post as possible.
Remove the single Phillips screw securing the IR board to the internal frame.
Één andere persoon heeft deze handleiding voltooid.
