Inleiding
Replace a faulty fan to keep temperatures low.
Wat je nodig hebt
Power down your Mac mini, disconnect all of the cables, and flip it over.
Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
The Jimmy should reach a stop about 3/8" down.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Disconnect the following connectors from the interconnect board:
IR board cable.
Fan cable.
18 andere personen hebben deze handleiding voltooid.
