Ga door naar hoofdinhoud
Mac mini Model A1176 Bottom Housing Replacement
Wat je nodig hebt
  1. Mac mini Model A1176 Bottom Housing Replacement, Top Housing: stap 1, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement, Top Housing: stap 1, afbeelding 2 van 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
  2. Mac mini Model A1176 Bottom Housing Replacement: stap 2, afbeelding 1 van 3 Mac mini Model A1176 Bottom Housing Replacement: stap 2, afbeelding 2 van 3 Mac mini Model A1176 Bottom Housing Replacement: stap 2, afbeelding 3 van 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
  3. Mac mini Model A1176 Bottom Housing Replacement: stap 3, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 3, afbeelding 2 van 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini Model A1176 Bottom Housing Replacement: stap 4, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 4, afbeelding 2 van 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini Model A1176 Bottom Housing Replacement: stap 5, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 5, afbeelding 2 van 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini Model A1176 Bottom Housing Replacement: stap 6, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 6, afbeelding 2 van 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
  7. Mac mini Model A1176 Bottom Housing Replacement, Internal Frame: stap 7, afbeelding 1 van 3 Mac mini Model A1176 Bottom Housing Replacement, Internal Frame: stap 7, afbeelding 2 van 3 Mac mini Model A1176 Bottom Housing Replacement, Internal Frame: stap 7, afbeelding 3 van 3
    • Later in this guide you will remove several recessed Phillips screws. Bit drivers are generally too large to fit in the recesses, so be sure to have a thin shafted Phillips screwdriver on hand.
    • First remove the AirPort antenna (the larger of the two), located near the power button.
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
  8. Mac mini Model A1176 Bottom Housing Replacement: stap 8, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 8, afbeelding 2 van 2
    • Use the tip of a spudger to slightly lift the left side of the ZIF cable lock up from its socket.
    • The ZIF cable lock will lift about 1 mm and stop. Do not try to completely remove the ZIF cable lock.
  9. Mac mini Model A1176 Bottom Housing Replacement: stap 9, afbeelding 1 van 1
    • Lift the audio board ribbon cable up out of its socket.
    • If it refuses to lift from its socket, the ZIF cable lock is not fully released. Make sure it is evenly lifted about 1 mm from the socket on the interconnect board.
  10. Mac mini Model A1176 Bottom Housing Replacement: stap 10, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 10, afbeelding 2 van 2
    • Rotate the mini so that the SuperDrive slot loading mechanism is facing you.
    • Use a pair of tweezers to lift the hard drive thermal sensor cable connector up off its socket on the logic board.
    • Use tweezers to grab the connector (as seen in the picture), not the wires.
    • The connector is located under the optical drive opening, next to the PRAM battery.
  11. Mac mini Model A1176 Bottom Housing Replacement: stap 11, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 11, afbeelding 2 van 2
    • In the next few steps, you will remove the four Phillips screws securing the internal frame to the bottom case. Included in each step is an overview picture showing the general location and a closeup showing the actual screw.
    • Remove the recessed Phillips screw near the power button securing the internal frame to the bottom housing.
  12. Mac mini Model A1176 Bottom Housing Replacement: stap 12, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 12, afbeelding 2 van 2
    • Remove the recessed Phillips screw near the sleep light securing the internal frame to the bottom housing.
    • This screw is the longest of the four screws securing the internal frame to the bottom case.
  13. Mac mini Model A1176 Bottom Housing Replacement: stap 13, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 13, afbeelding 2 van 2
    • Remove the Phillips screw from the internal frame near the Bluetooth antenna.
  14. Mac mini Model A1176 Bottom Housing Replacement: stap 14, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 14, afbeelding 2 van 2
    • Remove the Phillips screw near the audio ports securing the internal frame to the bottom case.
  15. Mac mini Model A1176 Bottom Housing Replacement: stap 15, afbeelding 1 van 2 Mac mini Model A1176 Bottom Housing Replacement: stap 15, afbeelding 2 van 2
    • Gently lift the internal frame up from the bottom housing, minding the AirPort antenna and any other cables that may get caught.
    • It may be necessary to pull up near the interconnect board to separate it from the logic board.
  16. Mac mini Model A1176 Bottom Housing Replacement, Logic Board: stap 16, afbeelding 1 van 1
    • Firmly grasp the power button cable connector with a pair of tweezers and lift it straight up off the logic board.
  17. Mac mini Model A1176 Bottom Housing Replacement: stap 17, afbeelding 1 van 1
    • Firmly grasp the sleep light cable connector with a pair of tweezers and lift it straight up off the logic board.
  18. Mac mini Model A1176 Bottom Housing Replacement: stap 18, afbeelding 1 van 1
    • Remove the single T10 torx lug securing the logic board to the bottom housing.
  19. Mac mini Model A1176 Bottom Housing Replacement: stap 19, afbeelding 1 van 1
    • Use the flat end of a spudger to slightly lift the logic board near the PRAM battery to separate it from the bottom housing.
    • It will be necessary to gently pull the sleep light (shown in red) away from the mini to clear the edge of the logic board.
  20. Mac mini Model A1176 Bottom Housing Replacement: stap 20, afbeelding 1 van 1
    • Gently lift the free end of the logic board and wiggle the board as you pull it away from the I/O ports.
  21. Mac mini Model A1176 Bottom Housing Replacement, Bottom Housing: stap 21, afbeelding 1 van 1
    • Remove the single Phillips screw securing the audio board to the bottom housing.
  22. Mac mini Model A1176 Bottom Housing Replacement: stap 22, afbeelding 1 van 1
    • Use a spudger to depress the metal finger (shown in red) while pushing the edge of the audio board upward with your thumb.
  23. Mac mini Model A1176 Bottom Housing Replacement: stap 23, afbeelding 1 van 1
    • Lift the free end of the audio board slightly and pull it away from the port side of the bottom housing.
    • Bottom housing remains.
Conclusie
10 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 6,812
