Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to replace a noisy worn-out fan.
Wat je nodig hebt
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
32 andere personen hebben deze handleiding voltooid.
3 opmerkingen
step 3 should have note to remove 3 ea. screws ... the screw on the left bottom on the picture is not shown ... it is obvious when you look at the fan you recieve ... connector came out very easy, just pull up (easily) ... took less than 15 minutes on my i7 server mini, mid 2011 model
DiSH
