Ga door naar hoofdinhoud
Mac Studio 2023 Housing Replacement
Wat je nodig hebt
    1. Mac Studio 2023 Housing Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 3 van 3
      • Completely shut down your Mac Studio.
      • Unplug all cables from your device.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Flip your Mac Studio over: stap 2, afbeelding 1 van 1
      • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 3 van 3
      • Adhesive strips secure the bottom cover screw pad.
      • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
      • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 3 van 3
      • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
      • This may take some force. If you're having trouble, apply more heat and try again.
      • Use the spudger to lift the pad and separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Separate the remaining adhesive: stap 5, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Separate the remaining adhesive: stap 5, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Separate the remaining adhesive: stap 5, afbeelding 3 van 3
      • Insert the flat end of a spudger under the pad.
      • Slide the spudger under the entire pad to separate the remaining adhesive.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Remove the bottom cover screw pad: stap 6, afbeelding 1 van 1
      • Remove the bottom cover screw pad.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Reassembly information: stap 7, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Reassembly information: stap 7, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Reassembly information: stap 7, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Tesa 61395 Tape
      $2.95
      • During reassembly:
      • If the adhesive strips are still sticky, you can reuse them.
      • If you're applying new adhesive:
      • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
      • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
      • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
      • Apply the new adhesive strips to the bottom cover and remove their liners.
      • Firmly press the bottom cover screw pad into its recess to secure it.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the bottom cover screws: stap 8, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the bottom cover screws: stap 8, afbeelding 2 van 2
      FixMat
      $36.95
      • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the bottom cover: stap 9, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the bottom cover: stap 9, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the bottom cover: stap 9, afbeelding 3 van 3
      • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
      • Remove the bottom cover.
      • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the power supply screws: stap 10, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the power supply screws: stap 10, afbeelding 2 van 2
      • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
      • Four 6 mm‑long screws
      • Two 7 mm‑long screws with washers
      • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 11, afbeelding 1 van 1
      • Flip your Mac Studio around so the rear ports are facing you.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Disconnect the power cord port cable: stap 12, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power cord port cable: stap 12, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power cord port cable: stap 12, afbeelding 3 van 3
      • A tight plastic latch secures the power cord port cable.
      • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
      • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Tilt up the power supply: stap 13, afbeelding 1 van 1
      • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
      • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
      • Be careful not to strain the cable that's still connected to the power supply.
      • Keep the power supply tilted up for the next step.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 3 van 3
      • A delicate plastic clip secures the power supply signal cable.
      • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Remove the power supply: stap 15, afbeelding 1 van 1
      • Remove the power supply.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 16, afbeelding 1 van 1
      • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the internal frame screws: stap 17, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the internal frame screws: stap 17, afbeelding 2 van 2
      • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
      • Seven 5 mm‑long screws
      • One 4 mm‑long screw
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Remove the internal frame: stap 18, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the internal frame: stap 18, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the antenna cable cover: stap 19, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the antenna cable cover: stap 19, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the antenna cable cover: stap 19, afbeelding 3 van 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the antenna cable cover.
      • Use tweezers or your fingers to remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Disconnect antenna 2: stap 20, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Disconnect antenna 2: stap 20, afbeelding 2 van 2
      • Insert one arm of a pair of angled tweezers under the metal neck of antenna 2's coaxial connector and lift straight up to disconnect it.
      • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove antenna 2's screws: stap 21, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove antenna 2's screws: stap 21, afbeelding 2 van 2
      • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 2.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Remove antenna 2: stap 22, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove antenna 2: stap 22, afbeelding 2 van 2
      • Remove antenna 2.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Disconnect antenna 3: stap 23, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect antenna 3: stap 23, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect antenna 3: stap 23, afbeelding 3 van 3
      • Insert one arm of a pair of angled tweezers under the metal neck of antenna 3's coaxial connector (next to antenna 2's connector) and lift straight up to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Unclip the cable: stap 24, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Unclip the cable: stap 24, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Unclip the cable: stap 24, afbeelding 3 van 3
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Remove antenna 3's screws: stap 25, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove antenna 3's screws: stap 25, afbeelding 2 van 2
      • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 3.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Remove antenna 3: stap 26, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove antenna 3: stap 26, afbeelding 2 van 2
      • Remove antenna 3.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the ethernet board cable cover: stap 27, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the ethernet board cable cover: stap 27, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the ethernet board cable cover: stap 27, afbeelding 3 van 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Disconnect the ethernet board: stap 28, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Disconnect the ethernet board: stap 28, afbeelding 2 van 2
      • Be very careful not to scrape off or damage any surface mounted components during this step.
      • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
      • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 29, afbeelding 1 van 1
      • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Remove the ethernet board cable: stap 30, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the ethernet board cable: stap 30, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the ethernet board cable: stap 30, afbeelding 3 van 3
      Flexible Extension
      $6.99
      • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
      • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement: stap 31, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement: stap 31, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement: stap 31, afbeelding 3 van 3
      • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
      • Don't pry against any surface mounted components.
      • Remove the cable.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Remove the ethernet board screws: stap 32, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the ethernet board screws: stap 32, afbeelding 2 van 2
      Flexible Extension
      $6.99
      • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
      • Be careful not to lose the washers, as they can fall off easily.
      Vraag FixBot
      Voeg opmerking toe
    7. Mac Studio 2023 Housing Replacement, Remove the ethernet board: stap 33, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the ethernet board: stap 33, afbeelding 2 van 2
      • Lift the ethernet board out of its recess and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 34, afbeelding 1 van 1
      • Reposition your Mac Studio so the SD card reader and two front USB‑C ports are facing you.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the speaker screws: stap 35, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the speaker screws: stap 35, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the speaker screws: stap 35, afbeelding 3 van 3
      • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Reposition the speaker: stap 36, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Reposition the speaker: stap 36, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Reposition the speaker: stap 36, afbeelding 3 van 3
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Disconnect the speaker: stap 37, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Disconnect the speaker: stap 37, afbeelding 2 van 2
      • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
      • Don't lift on the wires themselves, or you may damage them.
      • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Remove the speaker: stap 38, afbeelding 1 van 1
      • Remove the speaker.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the cable cover screws: stap 39, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the cable cover screws: stap 39, afbeelding 2 van 2
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
      • Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the cover: stap 40, afbeelding 1 van 1
      • Use tweezers or your fingers to remove the I/O board cable cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Disconnect the I/O board: stap 41, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the I/O board: stap 41, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the I/O board: stap 41, afbeelding 3 van 3
      • Use a spudger to pry up and disconnect both of the I/O board's press connectors.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Disconnect the power button: stap 42, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power button: stap 42, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the power button: stap 42, afbeelding 3 van 3
      • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
      • Use tweezers to gently pull the cable straight out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 43, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Remove the I/O board screws: stap 44, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the I/O board screws: stap 44, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the I/O board screws: stap 44, afbeelding 3 van 3
      Flexible Extension
      $6.99
      • Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
      • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
      • Partially tighten the four screws securing the board.
      • Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
      • With the cable plugged in and the board in position, fully tighten all four screws.
      • Unplug all cables before continuing.
      Vraag FixBot
      Voeg opmerking toe
    7. Mac Studio 2023 Housing Replacement, Remove the I/O board: stap 45, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the I/O board: stap 45, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the I/O board: stap 45, afbeelding 3 van 3
      • Lift the I/O board straight up and out of its recess to remove it.
      • During reassembly, lower the board into its recess, making sure the press connectors don't get trapped under the logic board.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Remove the power cord port: stap 46, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the power cord port: stap 46, afbeelding 2 van 2
      • Lift the power cord port out of its recess and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 47, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the USB‑C bracket: stap 48, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the USB‑C bracket: stap 48, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the USB‑C bracket: stap 48, afbeelding 3 van 3
      Flexible Extension
      $6.99
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 49, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 49, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 49, afbeelding 3 van 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the USB‑C port cable cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Disconnect the USB-C ports: stap 50, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Disconnect the USB-C ports: stap 50, afbeelding 2 van 2
      • Use the point of a spudger to pry up and disconnect the USB‑C port press connector from the logic board.
      • To reconnect press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 51, afbeelding 1 van 1
      • Carefully stand up your Mac Studio so the rear ports face up.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Remove the USB-C ports screws: stap 52, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the USB-C ports screws: stap 52, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the USB-C ports screws: stap 52, afbeelding 3 van 3
      Flexible Extension
      $6.99
      • Use a T5 Torx screwdriver to remove the two 5 mm‑long screws securing the USB-C ports.
      • Partially tighten the two screws securing the top of the ports.
      • Put the USB-C bracket into place and partially tighten the screw that secures it.
      • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cables should be easy to insert and remove.
      • With both cables plugged in and the ports in position, fully tighten all three screws.
      • Unplug any cables before continuing reassembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Mac Studio 2023 Housing Replacement, Remove the USB-C ports: stap 53, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the USB-C ports: stap 53, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the USB-C ports: stap 53, afbeelding 3 van 3
      • Use your fingers to lift the ports out of their recesses and remove them.
      • Don't try to remove an individual port. A flex cable connects them and can easily be damaged.
      • During reassembly, put the ports into their recesses, making sure the press connector stays above the logic board.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 54, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 55, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 55, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover: stap 55, afbeelding 3 van 3
      • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the back Thunderbolt 4 port cable cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Disconnect the ports: stap 56, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the ports: stap 56, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the ports: stap 56, afbeelding 3 van 3
      • Use a spudger to pry up and disconnect both Thunderbolt 4 cable press connectors from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 57, afbeelding 1 van 1
      • Carefully stand up your Mac Studio so the SD card reader and front two USB-C ports face up.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Remove the ports screws: stap 58, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the ports screws: stap 58, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the ports screws: stap 58, afbeelding 3 van 3
      Flexible Extension
      $6.99
      • Use a T5 Torx screwdriver to remove the six 5 mm‑long screws securing three of the ports.
      • Use a T7 Torx screwdriver to remove the two 8 mm‑long standoff screws securing the remaining port.
      • To align and install a set of ports during reassembly:
      • Partially tighten all four screws on a set of ports.
      • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cable should be easy to insert and remove.
      • With both cables plugged in and the port in position, fully tighten the screws.
      • Unplug all cables before continuing with reassembly.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement, Remove the ports: stap 59, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the ports: stap 59, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the ports: stap 59, afbeelding 3 van 3
      • Flex cables connect the two inner and two outer port pairs. Don't try to remove individual ports—you can easily damage the cables that connect them.
      • Use your fingers to lift the two inner or outer ports out of their recesses and remove them.
      • Repeat the process to remove the two other ports.
      • During reassembly, put the ports into their recesses, making sure the press connectors stay above the logic board.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 60, afbeelding 1 van 1
      • Reposition your Mac Studio so the power cord port is facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove the cable cover screws: stap 61, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover screws: stap 61, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the cable cover screws: stap 61, afbeelding 3 van 3
      • Use a T3 Torx screwdriver to remove the four 2 mm‑long screws securing the SDXC card reader cable covers.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Remove the cable covers: stap 62, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the cable covers: stap 62, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the cable covers: stap 62, afbeelding 3 van 3
      • Use tweezers or your fingers to remove the two cable covers.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Remove the cable: stap 63, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the cable: stap 63, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the cable: stap 63, afbeelding 3 van 3
      • Use the flat end of a spudger to pry up and disconnect the card reader cable press connector from the logic board.
      • Use the point of a spudger to disconnect the cable's other press connector from the reader itself.
      • Remove the cable.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Disconnect the card reader: stap 64, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Disconnect the card reader: stap 64, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Disconnect the card reader: stap 64, afbeelding 3 van 3
      • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the status indicator light cable ZIF connector, located on the right side of the card reader.
      Vraag FixBot
      Voeg opmerking toe
    6. Mac Studio 2023 Housing Replacement: stap 65, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement: stap 65, afbeelding 2 van 2
      • Very light adhesive secures the cable to the side of the card reader.
      • Use tweezers to gently pull the cable away from the card reader and separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    7. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 66, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    8. Mac Studio 2023 Housing Replacement, Remove the SDXC card reader screws: stap 67, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the SDXC card reader screws: stap 67, afbeelding 2 van 2
      Flexible Extension
      $6.99
      • Use a T5 Torx screwdriver to remove the two 6 mm‑long screws securing the card reader.
      Vraag FixBot
      Voeg opmerking toe
    9. Mac Studio 2023 Housing Replacement, Remove the card reader: stap 68, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the card reader: stap 68, afbeelding 2 van 2
      • Remove the card reader.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, Reposition your Mac Studio: stap 69, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    2. Mac Studio 2023 Housing Replacement, Remove antenna 1's screws: stap 70, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove antenna 1's screws: stap 70, afbeelding 2 van 2
      • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 1.
      Vraag FixBot
      Voeg opmerking toe
    3. Mac Studio 2023 Housing Replacement, Secure antenna 1: stap 71, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Secure antenna 1: stap 71, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Secure antenna 1: stap 71, afbeelding 3 van 3
      • Gently lay antenna 1 to the left of the heatsink, being careful not to strain its cable.
      • Secure antenna 1 to the logic board with a strip of painters tape.
      • Stick the tape to the heatsink screws, not directly onto the board.
      Vraag FixBot
      Voeg opmerking toe
    4. Mac Studio 2023 Housing Replacement, Remove the logic board assembly screws: stap 72, afbeelding 1 van 2 Mac Studio 2023 Housing Replacement, Remove the logic board assembly screws: stap 72, afbeelding 2 van 2
      • Use a T20 Torx screwdriver to remove the four 12 mm‑long screws securing the logic board assembly.
      Vraag FixBot
      Voeg opmerking toe
    5. Mac Studio 2023 Housing Replacement, Remove the logic board assembly: stap 73, afbeelding 1 van 3 Mac Studio 2023 Housing Replacement, Remove the logic board assembly: stap 73, afbeelding 2 van 3 Mac Studio 2023 Housing Replacement, Remove the logic board assembly: stap 73, afbeelding 3 van 3
      • Before trying to remove the logic board assembly, note the following:
      • The assembly sits very snugly in its housing. Take your time and don't try to force it out.
      • Only grip the assembly by areas on the logic board that don't have any components. Otherwise, you may damage the board.
      • Firmly secure the housing with one hand.
      • With your free hand, carefully lift the edge of the logic board assembly with the SSD modules until you can grip the fans. Slide the assembly towards the power cord cutout as necessary to help you lift it higher.
      • Grip the board and fans together and lift the assembly out of its housing.
      • Be careful not to damage any components on the edge of the assembly when removing it.
      • During reassembly, lower the logic board assembly into its housing at a downward angle so the side with a rubber gasket is facing the power cord cutout.
      Vraag FixBot
      Voeg opmerking toe
    1. Mac Studio 2023 Housing Replacement, You're left with the housing: stap 74, afbeelding 1 van 1
      • You're left with the housing.
      • Check your replacement housing for a power button. If doesn't have one, remove the button and transfer it to your new housing.
      • When reassembling your device, you'll need to transfer all the components you removed to the new housing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Spencer Day
201.855 Reputatie
1.244 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
86.246 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 99
Altijd: 1,473
