Ga door naar hoofdinhoud
Mac Pro Late 2013 Power Supply Replacement
Wat je nodig hebt
  1. Mac Pro Late 2013 Power Supply Replacement, Outer Case: stap 1, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement, Outer Case: stap 1, afbeelding 2 van 2
    • Slide the lock switch to the right, to the unlocked position.
  2. Mac Pro Late 2013 Power Supply Replacement: stap 2, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 2, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 2, afbeelding 3 van 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Mac Pro Late 2013 Power Supply Replacement, Fan Assembly: stap 3, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement, Fan Assembly: stap 3, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement, Fan Assembly: stap 3, afbeelding 3 van 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    You don't have to remove the fan assy to get to the wifi board & card. It can be done with the fan assy still attached.
    Fat Mango - Antwoord
    Fat Mango is correct. That said. If you do pull the fan assembly note that the screws are all held in with blue Permatex and breaking them free takes a fair amount of effort. Getting a good set of Torx screwdrivers is a must.
    Jim WIlson - Antwoord
    Hey guys, what would happen if you only replace one card.. I have a D300 but the plan is to upgrade to D500 or D600. So If I can afford and install one instead of the pair would it increase something? or will it cause any conflict? I guess I don’t understand if I the Mac Pro has 2 D300 graphic cards that means each has 1GB? Same as If I would Install 1 D600 that would increase 3GB only? Thanks.
    marcotamayo - Antwoord
    D300 = 2GB each card. Very few apps uses two cards at the same time.
    Gio Cas -
    The (5) Screws are Apple part number 923-0713
    Steven Gier - Antwoord
  4. Mac Pro Late 2013 Power Supply Replacement: stap 4, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 4, afbeelding 2 van 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Mac Pro Late 2013 Power Supply Replacement: stap 5, afbeelding 1 van 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
    On my Mac Pro (assembled mid-2017) these are T8 screws. In fact, there were no T7 screws anywhere in my machine.
    mark33 - Antwoord
    There was no bracket on top of the cable at all, so I got a bit confused, so I had to skip step 5 and 6.
    Rakesh - Antwoord
    On my machine, a TR7 worked to remove them due to the weird angle.
    Wilson Gaberino - Antwoord
  6. Mac Pro Late 2013 Power Supply Replacement: stap 6, afbeelding 1 van 1
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Mac Pro Late 2013 Power Supply Replacement: stap 7, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Mac Pro Late 2013 Power Supply Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
    You don't have to remove the fan assy to do the steps below. They can be done with the fan assy still attached.
  9. Mac Pro Late 2013 Power Supply Replacement, Lower Case: stap 9, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement, Lower Case: stap 9, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement, Lower Case: stap 9, afbeelding 3 van 3
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Mac Pro Late 2013 Power Supply Replacement: stap 10, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 10, afbeelding 2 van 2
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Mac Pro Late 2013 Power Supply Replacement, Interconnect Board: stap 11, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement, Interconnect Board: stap 11, afbeelding 2 van 2
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Mac Pro Late 2013 Power Supply Replacement: stap 12, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 12, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 12, afbeelding 3 van 3
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Mac Pro Late 2013 Power Supply Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
    These are actually 6.0mm T8 Torx Screws. 12/07/2016.
    Todd - Antwoord
    Ended up being T9 screws for me.
    Nathaniel Wilson - Antwoord
    mark33 - Antwoord
    These are T8 screws in my 2013 Mac Pro.
    Sangers - Antwoord
    T8 screws for me, i did and edit to this step
    Steve McGinn - Antwoord
    Ended up being T15 screws on my machine
    Spencer Curtis - Antwoord
  14. Mac Pro Late 2013 Power Supply Replacement: stap 14, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 14, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement: stap 14, afbeelding 3 van 3
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Mac Pro Late 2013 Power Supply Replacement: stap 15, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 15, afbeelding 2 van 2
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Mac Pro Late 2013 Power Supply Replacement: stap 16, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 16, afbeelding 2 van 2
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
  17. Mac Pro Late 2013 Power Supply Replacement, Power Supply Assembly: stap 17, afbeelding 1 van 1
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  18. Mac Pro Late 2013 Power Supply Replacement: stap 18, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 18, afbeelding 2 van 2
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
    those are t4 screws in my mac
    Andrzej Kiryluk - Antwoord
    T4s on mine, as well
    rwcinmsp - Antwoord
  19. Mac Pro Late 2013 Power Supply Replacement: stap 19, afbeelding 1 van 1
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  20. Mac Pro Late 2013 Power Supply Replacement: stap 20, afbeelding 1 van 1
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  21. Mac Pro Late 2013 Power Supply Replacement: stap 21, afbeelding 1 van 1
    • Remove the power supply assembly from the Mac Pro.
  22. Mac Pro Late 2013 Power Supply Replacement, Power Supply: stap 22, afbeelding 1 van 3 Mac Pro Late 2013 Power Supply Replacement, Power Supply: stap 22, afbeelding 2 van 3 Mac Pro Late 2013 Power Supply Replacement, Power Supply: stap 22, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the power supply DC-Out connector from its socket on the IO board.
    • Use the tip of a spudger to disconnect the power supply data cable from its socket on the IO board.
    • For both cables, make sure to pry straight up on the connector, and not the socket.
    Need to add T9 Torx Screwdriver to list of tools at the beginning of this article.
    htiek nworb - Antwoord
    When I gently pried up on the power supply data cable, the entire socket came right off the board. Now what?
    rwcinmsp - Antwoord
    Bought a new I/O board and got it back together. This little socket is held in only by 4 tiny solder joints. Suggest pressing down on the socket with a finger while gently prying up on the plug that snaps into it. (When reassembling, it presses in vertically.)
    rwcinmsp - Antwoord
  23. Mac Pro Late 2013 Power Supply Replacement: stap 23, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 23, afbeelding 2 van 2
    • Remove the four 9.0 mm silver T10 Torx screws from the sides of the power supply.
    • The power supply overhangs these screws somewhat, so you'll need to use a fixed screwdriver at a bit of an angle.
    I managed to untie the screws at an angle using the T9 screwdriver (instead of the T10) works well.
    Rakesh - Antwoord
    awesome. thank you for the tip!!
    samuel culper - Antwoord
    A T-10 tip used with a 4mm or 5/32” open-end wrench to loosen helps, too. (These really should be hex bolts…)
    MotorMac - Antwoord
  24. Mac Pro Late 2013 Power Supply Replacement: stap 24, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 24, afbeelding 2 van 2
    • Gently shift the power supply to free the AC power inlet cable out of its plastic clip.
    • Be careful not to try to separate the power supply from the IO board assembly just yet, as it is still connected by the AC power inlet cable.
  25. Mac Pro Late 2013 Power Supply Replacement: stap 25, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 25, afbeelding 2 van 2
    • Flip the power supply back to expose the AC power inlet cable.
  26. Mac Pro Late 2013 Power Supply Replacement: stap 26, afbeelding 1 van 2 Mac Pro Late 2013 Power Supply Replacement: stap 26, afbeelding 2 van 2
    • Squeeze the AC power inlet cable connector and pull it straight out of its socket in the power supply.
Conclusie
25 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
502.656 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.722 handleidingen geschreven
7 opmerkingen
Hey so any advice on how to test the psu once it’s out to confirm it is in fact in need of replacement?
John Doe - Antwoord
it works!
thanks much!
Thomas Paul - Antwoord
How do I purchase the Power Supply Module?
boinkboink - Antwoord
how did you make out? i just took my old PSU out, I was testing myself because I didn’t think I could actually take it apart!!! anyway, now I need to buy a new one. any suggestions?
samuel culper -
Hi, please where can I buy the PSU ?
Michael Tasker -
Where can I get this smps.. any lead please
shaik mohaideen - Antwoord
I also need to know where to buy a new PSU
Boan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 275
Altijd: 23,119
