Ga door naar hoofdinhoud
Inleiding
Use this guide to remove the bottom of the outer case of your Mac Pro.
Onderdelen
Geen onderdelen opgegeven.
  1. Slide the lock switch to the right, to the unlocked position. Slide the lock switch to the right, to the unlocked position.
    • Slide the lock switch to the right, to the unlocked position.
  2. Lift the outer case straight up off the Mac Pro. It may help to push down on the center of the fan while lifting the case up. It may help to push down on the center of the fan while lifting the case up.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Flip the Mac Pro upside down, 180 degrees. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  4. Carefully lift the lower case up and remove it from the Mac Pro. Carefully lift the lower case up and remove it from the Mac Pro.
    • Carefully lift the lower case up and remove it from the Mac Pro.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
477.150 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
138 Leden
17.020 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 27
Altijd: 2,358
