Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. Deze stap is niet vertaald. Help het te vertalen
    Slide the lock switch to the right, to the unlocked position. Slide the lock switch to the right, to the unlocked position.
    • Slide the lock switch to the right, to the unlocked position.
  2. Deze stap is niet vertaald. Help het te vertalen
    Lift the outer case straight up off the Mac Pro. It may help to push down on the center of the fan while lifting the case up. It may help to push down on the center of the fan while lifting the case up.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Deze stap is niet vertaald. Help het te vertalen
    Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. Deze stap is niet vertaald. Help het te vertalen
    The fan assembly is attached to the rest of the computer by two cables on the IO board side. Tilt the assembly up away from the IO board.
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. Deze stap is niet vertaald. Help het te vertalen
    While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Deze stap is niet vertaald. Help het te vertalen
    Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Deze stap is niet vertaald. Help het te vertalen
    Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board. Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Deze stap is niet vertaald. Help het te vertalen
    Disconnect the fan assembly antenna cable from the IO board.
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Deze stap is niet vertaald. Help het te vertalen
    Flip the Mac Pro upside down, 180 degrees. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case. Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
  10. Deze stap is niet vertaald. Help het te vertalen
    Carefully lift the lower case up and remove it from the Mac Pro. Carefully lift the lower case up and remove it from the Mac Pro.
    • Carefully lift the lower case up and remove it from the Mac Pro.
  11. Deze stap is niet vertaald. Help het te vertalen
    Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection. Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
  12. Deze stap is niet vertaald. Help het te vertalen
    Gently separate the other side as well. Flip the connector up and out of the way of the graphics card. Repeat this procedure on the other graphics card.
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    • Repeat this procedure on the other graphics card.
  13. Deze stap is niet vertaald. Help het te vertalen
    Remove the two 6.0 mm T7 Torx screws securing the interconnect board to the heat sink.
    • Remove the two 6.0 mm T7 Torx screws securing the interconnect board to the heat sink.
  14. Deze stap is niet vertaald. Help het te vertalen
    Gently walk the interconnect board straight up off the logic board's slot connection. It is recommended to lift one side and then the other. Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
    • Gently walk the interconnect board straight up off the logic board's slot connection.
    • It is recommended to lift one side and then the other.
    • Do not try to remove the interconnect board from the Mac Pro yet, as it is still connected to the IO board.
  15. Deze stap is niet vertaald. Help het te vertalen
    Flip the interconnect board up and over, exposing the IO board data cable. Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
    • Flip the interconnect board up and over, exposing the IO board data cable.
    • Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
  16. Deze stap is niet vertaald. Help het te vertalen
    Use the flat end of a spudger to separate the other side of the IO board data cable. Bend the cable out of the way and remove the interconnect board from the Mac Pro.
    • Use the flat end of a spudger to separate the other side of the IO board data cable.
    • Bend the cable out of the way and remove the interconnect board from the Mac Pro.
  17. Deze stap is niet vertaald. Help het te vertalen
    Flip the Mac Pro back over and set it gently on a flat surface.
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  18. Deze stap is niet vertaald. Help het te vertalen
    Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side). Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
  19. Deze stap is niet vertaald. Help het te vertalen
    Remove the power supply cage from the top of the power supply.
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  20. Deze stap is niet vertaald. Help het te vertalen
    Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  21. Deze stap is niet vertaald. Help het te vertalen
    Remove the power supply assembly from the Mac Pro.
    • Remove the power supply assembly from the Mac Pro.
  22. Deze stap is niet vertaald. Help het te vertalen
    Remove two 5.5 mm T8 Torx screws.
    • Remove two 5.5 mm T8 Torx screws.
  23. Deze stap is niet vertaald. Help het te vertalen
    Remove four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
    • Remove four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
    • Remove only the outer four of the eight screws.
  24. Deze stap is niet vertaald. Help het te vertalen
    At this point, the logic board is held onto the heat sink by thermal compound. You may need to gently pry with a spudger to separate the logic board from the heat sink.
    • At this point, the logic board is held onto the heat sink by thermal compound.
    • You may need to gently pry with a spudger to separate the logic board from the heat sink.
    • Be very careful not to bend and break the logic board.
    • Remove the logic board from the heat sink.
  25. Deze stap is niet vertaald. Help het te vertalen
    Remove the inner four 12.8 mm T10 Torx screws from the CPU heat sink bracket. Remove the CPU heat sink bracket.
    • Remove the inner four 12.8 mm T10 Torx screws from the CPU heat sink bracket.
    • Remove the CPU heat sink bracket.
  26. Deze stap is niet vertaald. Help het te vertalen
    Remove the second heat sink bracket.
    • Remove the second heat sink bracket.
  27. Deze stap is niet vertaald. Help het te vertalen
    Lift and remove the logic board from the CPU and bracket. During reassembly, be sure to clean off and replace the thermal compound on the CPU.
    • Lift and remove the logic board from the CPU and bracket.
    • During reassembly, be sure to clean off and replace the thermal compound on the CPU.
    • We have a thermal paste guide that makes replacing the thermal compound easy.
Eindstreep
8 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
466.912 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
135 Leden
14.475 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 140
Altijd: 10,171
