Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the lock switch to the right, to the unlocked position.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
Carefully lift the lower case up and remove it from the Mac Pro.
Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
Gently separate the other side as well.
Flip the connector up and out of the way of the graphics card.
Remove the two 6.0 mm T8 Torx screws securing the interconnect board to the heat sink.
Gently walk the interconnect board straight up off the logic board's slot connection.
Flip the interconnect board up and over, exposing the IO board data cable.
Use the same sort of twisting and spreading motion with the flat end of a spudger to separate one side of the IO board data cable.
Use the flat end of a spudger to separate the other side of the IO board data cable.
Bend the cable out of the way and remove the interconnect board from the Mac Pro.
7 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Why is it necessary to remove the fan?
