Ga door naar hoofdinhoud
Mac Pro Late 2013 Graphics Card Replacement
Wat je nodig hebt
  1. Mac Pro Late 2013 Graphics Card Replacement, Outer Case: stap 1, afbeelding 1 van 2 Mac Pro Late 2013 Graphics Card Replacement, Outer Case: stap 1, afbeelding 2 van 2
    • Slide the lock switch to the right, to the unlocked position.
    Vraag FixBot
  2. Mac Pro Late 2013 Graphics Card Replacement: stap 2, afbeelding 1 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 2, afbeelding 2 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 2, afbeelding 3 van 3
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
    Vraag FixBot
  3. Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: stap 3, afbeelding 1 van 3 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: stap 3, afbeelding 2 van 3 Mac Pro Late 2013 Graphics Card Replacement, Fan Assembly: stap 3, afbeelding 3 van 3
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    Vraag FixBot
  4. Mac Pro Late 2013 Graphics Card Replacement: stap 4, afbeelding 1 van 2 Mac Pro Late 2013 Graphics Card Replacement: stap 4, afbeelding 2 van 2
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
    Vraag FixBot
  5. Mac Pro Late 2013 Graphics Card Replacement: stap 5, afbeelding 1 van 1
    • While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
    Vraag FixBot
  6. Mac Pro Late 2013 Graphics Card Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
    Vraag FixBot
  7. Mac Pro Late 2013 Graphics Card Replacement: stap 7, afbeelding 1 van 2 Mac Pro Late 2013 Graphics Card Replacement: stap 7, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
    Vraag FixBot
  8. Mac Pro Late 2013 Graphics Card Replacement: stap 8, afbeelding 1 van 1
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
    Vraag FixBot
  9. Mac Pro Late 2013 Graphics Card Replacement, Lower Case: stap 9, afbeelding 1 van 3 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: stap 9, afbeelding 2 van 3 Mac Pro Late 2013 Graphics Card Replacement, Lower Case: stap 9, afbeelding 3 van 3
    • Flip the Mac Pro upside down, 180 degrees.
    • Remove five 5.1 mm T10 Torx screws from the outer perimeter of the lower case.
    Vraag FixBot
  10. Mac Pro Late 2013 Graphics Card Replacement: stap 10, afbeelding 1 van 2 Mac Pro Late 2013 Graphics Card Replacement: stap 10, afbeelding 2 van 2
    • Carefully lift the lower case up and remove it from the Mac Pro.
    Vraag FixBot
  11. Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: stap 11, afbeelding 1 van 2 Mac Pro Late 2013 Graphics Card Replacement, Graphics Card: stap 11, afbeelding 2 van 2
    • Use the flat end of a spudger and a twisting motion to gently separate one side of the graphics card data connection.
    Vraag FixBot
  12. Mac Pro Late 2013 Graphics Card Replacement: stap 12, afbeelding 1 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 12, afbeelding 2 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 12, afbeelding 3 van 3
    • Gently separate the other side as well.
    • Flip the connector up and out of the way of the graphics card.
    Vraag FixBot
  13. Mac Pro Late 2013 Graphics Card Replacement: stap 13, afbeelding 1 van 1
    • Remove the two 6.6 mm T8 Torx Security screws securing the GPU to the Mac Pro.
    • These screws fit into power cables behind the GPU. Be careful not to over-tighten and twist the cables.
    Vraag FixBot
  14. Mac Pro Late 2013 Graphics Card Replacement: stap 14, afbeelding 1 van 1
    • Remove the four 8.4 mm T10 screws from the GPU heat sink bracket.
    Vraag FixBot
  15. Mac Pro Late 2013 Graphics Card Replacement: stap 15, afbeelding 1 van 1
    • Remove the GPU heat sink bracket.
    Vraag FixBot
  16. Mac Pro Late 2013 Graphics Card Replacement: stap 16, afbeelding 1 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 16, afbeelding 2 van 3 Mac Pro Late 2013 Graphics Card Replacement: stap 16, afbeelding 3 van 3
    • The graphics card is now held onto the central heat sink by thermal compound.
    • You may need to pry very gently with a spudger to separate the card from the heat sink.
    • Remove the graphics card from the heat sink.
    Vraag FixBot
  17. Mac Pro Late 2013 Graphics Card Replacement: stap 17, afbeelding 1 van 1
    • During reassembly, be sure to clean off and replace the thermal compound. Use our Applying Thermal Paste guide if you require assistance.
    • Repeat this procedure if you wish to remove the secondary graphics card.
    Vraag FixBot
Conclusie
48 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
514.884 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.699 handleidingen geschreven
20Gids Commentaar
hey! is it possible to upgrade the GPU or is this just for replacing exactly the same part?
Ben - Antwoord Deel
I am guessing you can upgrade them with OEM parts, but where would we find them?
Fernando Bernardino - Antwoord Deel
Yes. I recently swapped out D300 pairs for D700 pairs without a blip. I did an NVRAM reset afterwards just to be safe.
Technology Research - Antwoord Deel
I have the D300s, and would like to upgrade to the D500s or D700s. Where might I find the replacement graphics cards? Also, any recommendations on service providers who would do this procedure?
Chris M Balz - Antwoord Deel
I'd love to know this as well. The only reason I picked up the ,ad pro was the potential for upgrades. As it turns out D300s are crap. I can't even run boot camp properly.
jerimiahy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 436
Altijd: 115,946
