Inleiding
This Guide walks you through the steps to replace the original enclosure latch with a version that contains a hole for attaching a cable lock. This solution also prevents the enclosure from being able to be opened.
Wat je nodig hebt
Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
Using a T5 screwdriver, remove the six screws retaining the latch on the inside of the enclosure and lift out the retainer plate.
Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
This guide will help you secure your Mac Pro (2013) with any cable lock.
Één andere persoon heeft deze handleiding voltooid.
