Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the lock switch to the right, to the unlocked position.
Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
While supporting the fan assembly with one hand, loosen the two T8 captive screws in the fan cable bracket.
Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
Disconnect the fan assembly antenna cable from the IO board.
Remove the fan assembly from the Mac Pro.
Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
Remove the fan assembly lid.
Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
Lift and remove the metal cover from the AirPort board bay.
Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
Remove the fan assembly ribbon cable from its ZIF socket.
Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
Disconnect the fan ribbon cable.
Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
3 andere personen hebben deze handleiding voltooid.
