Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide to replace the AirPort antenna array in your Mac Pro.
  1. Slide the lock switch to the right, to the unlocked position. Slide the lock switch to the right, to the unlocked position.
    • Slide the lock switch to the right, to the unlocked position.
  2. Lift the outer case straight up off the Mac Pro. It may help to push down on the center of the fan while lifting the case up. It may help to push down on the center of the fan while lifting the case up.
    • Lift the outer case straight up off the Mac Pro.
    • It may help to push down on the center of the fan while lifting the case up.
  3. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly. Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
    • Remove five 5.1 mm T10 Torx screws from around the outer perimeter of the fan assembly.
  4. The fan assembly is attached to the rest of the computer by two cables on the IO board side. Tilt the assembly up away from the IO board.
    • The fan assembly is attached to the rest of the computer by two cables on the IO board side.
    • Tilt the assembly up away from the IO board.
    • Do not try to remove the fan assembly yet, as it is still attached by two cables.
  5. While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • While supporting the fan assembly with one hand, loosen the two T7 captive screws in the fan cable bracket.
    • These screws are captive in the Mac Pro. Do not try to remove these screws from your Mac Pro.
  6. Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
    • Use a pair of tweezers to pull the fan cable bracket away from the fan assembly.
  7. Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board. Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
    • Use the flat end of a spudger to disconnect the fan assembly ribbon cable from the IO board.
  8. Disconnect the fan assembly antenna cable from the IO board.
    • Disconnect the fan assembly antenna cable from the IO board.
    • Remove the fan assembly from the Mac Pro.
  9. Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly. Remove the fan assembly lid. Remove the fan assembly lid.
    • Use the flat end of a spudger to pry the fan assembly lid up off the fan assembly.
    • Remove the fan assembly lid.
  10. Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
    • Remove the three 3.7 mm T4 screws securing the metal cover to the AirPort board bay.
  11. Lift and remove the metal cover from the AirPort board bay.
    • Lift and remove the metal cover from the AirPort board bay.
  12. Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector. Remove the fan assembly ribbon cable from its ZIF socket. Remove the fan assembly ribbon cable from its ZIF socket.
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan assembly ribbon cable connector.
    • Remove the fan assembly ribbon cable from its ZIF socket.
  13. Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable. Disconnect the fan ribbon cable. Disconnect the fan ribbon cable.
    • Use the tip of a spudger to flip the ZIF retaining tab on the fan ribbon cable.
    • Disconnect the fan ribbon cable.
  14. Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
    • Remove the three 3.7 mm T4 screws securing the antenna array to the fan assembly.
  15. Remove the AirPort antenna array.
    • Remove the AirPort antenna array.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
467.167 Reputatie
410 handleidingen geschreven
iFixit Lid van iFixit
Community
133 Leden
14.562 handleidingen geschreven
having macpro 2013 bluetooth on issue, where is the bluetooth module locate?
Sanong - Antwoord
is bluetooth module part of (inside) airport board?
Sanong - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 39
Altijd: 3,736
