Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Prereq only when logic board is out.
  1. Pull the hard drive away from the front edge of the mini and remove it from the outer case. During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
    • Pull the hard drive away from the front edge of the mini and remove it from the outer case.
    • During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
    • There are two pairs of holes in the case. Insert the pins into the holes closest to the bottom of the case.
  2. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 936
