Ga door naar hoofdinhoud
MSI VR601 WiFi card Replacement
Wat je nodig hebt
  1. MSI VR601 WiFi card Replacement, Open the back cover: stap 1, afbeelding 1 van 2 MSI VR601 WiFi card Replacement, Open the back cover: stap 1, afbeelding 2 van 2
    • Start by taking out the battery and charger. No power should be connected.
    • Unscrew the 4 Phillips #1 screws marked in the photo.
    • This screw is hidden under the Warranty void sticker!
    • All screws are the same length, so don't worry about mixing them up
    • Use a spudger or your finger to gently but firmly open the cover.
    • It's stuck in there with clips, so be a little careful. (Remember; If you feel like you're using too much force, you probably are).
  2. MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: stap 2, afbeelding 1 van 2 MSI VR601 WiFi card Replacement, Identify the WiFi card and remove: stap 2, afbeelding 2 van 2
    • The WiFi card has two antenna cables (one white and one black).
    • Use a spudger to carefully unhook the antenna contacts.
    • Unscrew the Phillips #0 screw holding the WiFi card down. (This is not the same screw as the others).
  3. MSI VR601 WiFi card Replacement, Replace WiFi card: stap 3, afbeelding 1 van 1
    • Take the old card out of the mini PCI Express slot, and replace with a new and compatible card.
    • In my case I only had a direct replacement, which only supports 802.11b/g standards.
Conclusie
Geir Ove Andersen
7.980 Reputatie
5 handleidingen geschreven
Master Techs Lid van Master Techs
Community
327 Leden
1.699 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 29
Altijd: 343
