Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
First, turn off the computer and unplug the power cord.
Flip laptop over so that you are looking at the bottom of the laptop.
Put your left pointer finger on the switch labeled "Battery lock" and your right pointer finger on the switch labeled "Release".
Switch the tab labeled "Battery lock" to the unlocked position.
Slide the tab labeled "Release" to the right and hold it down.
While holding the "Release" tab to the right, slide the battery out with your left hand.
