Inleiding
This guide will show you how to replace the battery inside of the MSI PE70 6QE-035US. If your device has been having problems turning on or just shutting off too fast, this guide could be your solution. Be sure to complete this guide on any hard surface or area that will not create static electricity.
Wat je nodig hebt
Start by flipping the device over to the backside.
Using the Phillips #0 screwdriver bit, unscrew all screws on the back panel.
Één andere persoon heeft deze handleiding voltooid.
