Ga door naar hoofdinhoud
MSI MS-1782 Back Cover Replacement
Wat je nodig hebt
  1. MSI MS-1782 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Back Cover Replacement: stap 2, afbeelding 1 van 3 MSI MS-1782 Back Cover Replacement: stap 2, afbeelding 2 van 3 MSI MS-1782 Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
Conclusie
Joshua Pizzo
438 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 328
