Ga door naar hoofdinhoud
MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement
Wat je nodig hebt
  1. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement, SSD/Hard Drive: stap 1, afbeelding 1 van 1
    • Remove the four rear screws using the Phillips #0 screwdriver from the laptop as shown. The screws are 0.5 inches long.
  2. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 2, afbeelding 1 van 2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Using the black nylon spudger, carefully remove the rear cover from the laptop.
  3. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 3, afbeelding 1 van 3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 3, afbeelding 2 van 3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Carefully unplug the battery and remove it from the laptop. This will be held down with adhesive, but can be safely removed once unplugged.
  4. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 4, afbeelding 1 van 2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove each screw from the heatsink and remove it.
  5. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 5, afbeelding 1 van 3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 5, afbeelding 2 van 3 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Using the Phillips #0 screwdriver, remove each screw from the SSD card units, then unplug and remove them. The screws are 0.25 inches long.
  6. MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 6, afbeelding 1 van 2 MSI GT75VR 7RF Titan Pro SSD/Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove all screws from the back of the hard drive using the Phillips #0 screwdriver, then lift up and unplug the unit. Screws are 0.15625 inches long.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 1,546
