Inleiding
This guide will tell MSI GT72 2QE Dominator Pro users how to replace a defective battery. It is a medium-level process that takes 15-20 minutes to complete.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Use a Phillips screwdriver to remove the seven 6mm screws from the bottom of the laptop.
Lift and remove the bottom case off of the laptop.
Run MSI Battery Calibration to make sure the firmware can see the new batteries cycle high low voltages.
29 andere personen hebben deze handleiding voltooid.
17 opmerkingen
Hi,
on the steep 7, you forgot a screw : just above the orange part of the heat sink.
great guide otherwise :D
And another one near the bass speaker
Did it but I was left with one screw. Have no idea where it goes. But hey battery works and not complaining.
Anyone know where to find a GT72 Dominator battery?
I bought mine here: http://www.fr-batterie.com/
Thanks for this tutorial!
I used it to replace my GT72 2QD Dominator battery. It’s almost the same (yet, not a piece of cake).
Cameron -
