Ga door naar hoofdinhoud
MSI GT62VR 6RD Dominator Battery Replacement
Wat je nodig hebt
  1. MSI GT62VR 6RD Dominator Battery Replacement, Battery: stap 1, afbeelding 1 van 2 MSI GT62VR 6RD Dominator Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
  2. MSI GT62VR 6RD Dominator Battery Replacement: stap 2, afbeelding 1 van 2 MSI GT62VR 6RD Dominator Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
    • The laptop cover will break if it is being handled roughly.
    • Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
    • Remove the back plate.
  3. MSI GT62VR 6RD Dominator Battery Replacement: stap 3, afbeelding 1 van 3 MSI GT62VR 6RD Dominator Battery Replacement: stap 3, afbeelding 2 van 3 MSI GT62VR 6RD Dominator Battery Replacement: stap 3, afbeelding 3 van 3
    • Locate the battery.
    • The wires are located at the back end of the battery and covered in tape.
    • Remove the tape covering the battery connector.
    • Place your hands at the corners of the wires.
    • Pull upward from the back end of the battery where the wires are located.
    • Remove the battery.
Conclusie
Rebekah Johnson
147 Reputatie
1 Handleiding geschreven
Één opmerking
Can i use it using chargine cable even if i remove rhe battery?
Tabs XXIV - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 1,949
